Intermittent issues of will not stay running and deceleration at cruising speeds
1992 LINCOLN TOWN CAR
103,000 MILES • V8 • 2WD • AUTOMATIC
DESIREE2323
  • 5 POSTS
I have 2 intermittent issues to address.
Issue 1. Engine suddenly shuts off. I turn the key to start engine, engine starts, then suddenly shuts off before I can shift into reverse. Try starting it again, turn key, engine starts, give it gas for about 20 seconds, and engine stays running. This doesn’t happen on every start up either.
Issue 2. Deceleration at cruising speeds: I’ve noticed that around 45-50 MPH the car starts to lag or slow down for a couple seconds. It feels like it’s struggling to maintain the speed. I’d like to mention that I have never used the cruise control feature while I’ve owned this car.
This doesn’t happen every time I drive it either. Any help would be appreciated. Thanks!
Mar 20, 2021 at 2:53 PM
The symptoms can be caused by a few things. My first thought is there is low fuel pressure to the engine. However, we need to do a little checking before we start replacing things.
What I need you to do is scan the computer to see if there are diagnostic trouble codes stored. If there are, they should point us in the right direction.
Here is a link that shows how it is done. This vehicle has an OBD1 system and it doesn't require a scan tool to retrieve codes.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Perform the scan and let me know what you find.
Mar 21, 2021 at 7:33 PM
DESIREE2323
  • 5 POSTS
Hi Joe,
So I tried what you suggested but got no flashes. The test light remained on and solid when the key was turned to the on position and when I started the vehicle. I made sure it was hooked up properly and double/triple checked. What does this mean?
Mar 24, 2021 at 4:16 AM
Even if there weren't any codes stored, the light should have flashed indicating the test is over. You got nothing? Has the battery been disconnected recently?
Mar 24, 2021 at 5:52 PM
