Running great but slowly shut off on the highway, with less and less power. I thought I could limp it home but within only a couple of minutes it would no longer run. It would almost start but not quite. Towed home. Fuel pump runs for 2 seconds when the key is turned on and is showing about 50 lbs. pressure. Compressions at least 150 lbs. Plugs all firing and when out and cranking I can smell gas. Test light on individual injectors shows blinking lights on cranking. Downpipe and exhaust disconnected, so they aren't plugged. Crankshaft position indicator removed, and resistance checks out, and changes with temperature. Cylinder head sensor removed and changes resistance with temperature change. Timing chain hasn't skipped. It cranks fine and almost starts but not quite, or it barely starts but won't run. Tachometer not showing RPMs during cranking. No codes showing on my cheap OBDII code reader. Spraying a little starting fluid into the throttle body changes nothing. With the key on the Security light stays on for about 4 seconds. I'm out of ideas.
Jan 18, 2022 at 10:34 AM
