How does it sound when it is cranking over? Can you upload a short video so I can hear it that way I can make sure the engine is not hurt. Also, let's check for spark which video will help you do.
https://youtu.be/baq_aEWNQ0Y?si=XFPy1s3jM04lRKV9
Please go over this guide as well:
https://www.2carpros.com/articles/starter-not-working-repair
If there is no spark, I would swap out the crankshaft angle sensor here is the location of the sensor in case, you need it. Check out the images (below). Please let us know what happens.
Jul 14, 2024 at 10:13 AM
