If I brought in a 1996 Toyota Estima, wide body, Supercharged with 147,000ks in excellent condition, extremely well maintained and said “the symptoms were when you start engine in the morning, engine misfires briefly and then after 5 -10 seconds returns to normal idling. doesn’t happen when driving and that I’d phoned around and canvassed a few opinions as to possible causes and was told subject to viewing and inspecting, the verdict appears to be either distributor or leads, spark plugs, inlet manifold, rocker cover gasket leaking, or head gasket problem, but as the distributor leads were done recently, they can be eliminated. so could you please diagnose the problem,” how would you proceed to diagnose the problem and what would you do?
Apr 20, 2021 at 4:57 PM
