transmission control module connector is damaged?
2007 LINCOLN MKZ
149,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
GREG GARCIA
As I'm looking in the manual booklet it gives me the transmission description (Aisin AW F21 Automatic transaxle (TR-VX.) Code B. So, the female connector is damaged that goes into the control module. What wires go to which pins. Thank you...
Mar 11, 2025 at 2:56 PM
Sure, here is the wiring diagrams for the transmission control module. Thanks for the images they helped. Check out the images (below). Let us know if you need anything else.
Mar 12, 2025 at 11:36 AM
GREG GARCIA
do you have the pinout for the connector?
Mar 12, 2025 at 12:38 PM
No, I am sorry we don't. You can see the terminal numbers though which should be on the connector.
Mar 13, 2025 at 8:30 AM
