engine cuts out on hot days after driving it for a little
1995 PLYMOUTH NEON
136,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
JUSTINAPACHE95
  • 9 POSTS
Ok I have a 1995 neon on any day it will start and idle fine I drive 20 mins to work every morning and it runs fine and have never had any issue at night but on hot days like 80 degree plus days if I try to make that same trip home and back it will start to cut out and then soon after die but while its cutting out if I barely press on the gas peddle it will slowly accelerate but if I put the peddle to the floor it pop and will just come to a stop one it will no longer run or start I let it sit for like 20 mins to an hour it will start and run fine but not for long if I let it sit long enough for the temp gauge to go all the way down it runs as if nothing was ever wrong I put a new ignition coil on today and after I put it on I started the car and it started missing as soon as I tried to give it an gas I put the old one back on and it throttles up just fine re hooked up new one and it wouldn't even start please help me
Sep 18, 2015 at 5:19 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it 48 psi
Sep 19, 2015 at 6:19 AM
JUSTINAPACHE95
  • 9 POSTS
I will do that for sure but do u have any idea why whenni put the new coil on it misses no matter what but if I put the old one on it runs fine till it gets really hot out
Sep 19, 2015 at 11:27 AM
HMAC300
  • 48,601 POSTS
no idea as I can't see it. scan for codes as well
Sep 19, 2015 at 12:32 PM
JUSTINAPACHE95
  • 9 POSTS
Check engine light is off but it has an o2 sensor code and random cylinder misfire
Sep 19, 2015 at 12:53 PM
HMAC300
  • 48,601 POSTS
random misfires are hard to diagnose and should be left to pros. do what I've said in replies
Sep 19, 2015 at 1:34 PM
JUSTINAPACHE95
  • 9 POSTS
It had the light on a few days ago
Sep 19, 2015 at 1:44 PM
HMAC300
  • 48,601 POSTS
if you don't care to do what I suggested then I have no further comments nor answers.
Sep 19, 2015 at 3:16 PM
JUSTINAPACHE95
  • 9 POSTS
I will do what u say I was just telling ya what I have done and my concerns I just don't have the cash today to get a fuel line pressure tester
Sep 19, 2015 at 3:36 PM
JUSTINAPACHE95
  • 9 POSTS
I checked the fuel pressure at the fuel rail the gauge says 0psi
Sep 20, 2015 at 3:36 PM
HMAC300
  • 48,601 POSTS
do it with engine running if it will start otherwise looks like you need a fuel pump
Sep 20, 2015 at 4:10 PM
JUSTINAPACHE95
  • 9 POSTS
I did the test with it running it said 0psi but I drive the car everyday it only starts acting up once u drive it for awhile when its hot out it has never done it at night either it just starts to sputter when u give it gas and then it eventually just stalls and won't start until it sits for a little bit the runs fine for a little while then it starts all over till it quits again
Sep 21, 2015 at 9:01 AM
JUSTINAPACHE95
  • 9 POSTS
Check engine light is on again codes are p0505 idle air control valve malfunction, p0139 o2 sensor, p0171 an under reporting mass air flow sensor
Sep 21, 2015 at 9:08 AM
HMAC300
  • 48,601 POSTS
have alocal pro look at this I think you have a fuel pump problem causing a couple of the codes. for idle air try cleaning iac hole and throttle plate on both sides with choke cleaner. I have no other suggestions or comments for you.
Sep 21, 2015 at 9:24 AM
JUSTINAPACHE95
  • 9 POSTS
OK thank you for all the help
Sep 21, 2015 at 9:57 AM
