I will get back soon, I have a situation happening!
You do not have points----you have Prestolite ignition.
For right now---crank it up
Jiggle (not manhandle) your wires. Duplicate bouncing down the road. Not yanking and snatching. Even simulate "Pulling Gs" in left and right turns. Sometimes a wire may be melted or skinned and grounding out on metal.
Be gentle!
The wires coming out of a Prestolite distributor are two small solid copper wires. Tied down (helps) or not, I've seen them break and continue to have intermittent contact. Don't stop there!
Jiggle methodically everywhere, not in a race! If the engine sputters or shuts off make a note of where you jiggled!
Be aware that some of those pesky moving parts under the hood are out to get you. Be careful!
I had multiple problems with my '77s Prestolite, I finally upgraded to Duraspark (Motorcraft) which came out in 1979 in CJs, I have not had any issues since (other Jeeps I had were Motorcraft, So I knew how much better it is)
I guess my upgrade ran about $100.00, we can discuss that more in depth if its needed, Here's a link to sorta look over, yours could be slightly different. I'm not saying you must do this!
https://www.2carpros.com/questions/prestolite-to-motorcraft-conversion-1976-cj7
Find something? Let me know, I may have a better way to attack it.
The Medic
Jul 20, 2021 at 6:53 PM
