Engine cranks but does not start, and multiple codes?
2010 TOYOTA SEQUOIA
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BERROU
I'm getting these p errors: P0010, P0013, P0020, P0102, p0113, P0118, p0121, p0123, p0338, p0343, p0348, p0368, p0393, p0553, p0778, p1343, p2135, p2716 and C1201. Engine cranks but won't start. Is my ECU damaged? I checked the cables by multimeter from many of the sensors to the ecu connector d74 and there's no problem. I Checked the fuses, no ground short, new battery, half fuel tank. I cleaned the throttle and MAF, and replaced the spark plug then it worked, later I changed the battery, and cleaned contact d74 and it shut off.
Jun 11, 2023 at 1:37 PM
The error codes you provided are related to various components and systems in your vehicle. While it's difficult to pinpoint the exact cause without further diagnostic information, it's unlikely that a damaged ECU (Engine Control Unit) is the sole reason for the engine cranking but not starting.
Here are some insights into a few of the error codes you mentioned:
P0010, P0013, P0020: These codes are related to the camshaft position actuator circuit. They indicate potential issues with the variable valve timing system.
P0102: This code indicates a problem with the Mass Air Flow (MAF) sensor circuit. It could be caused by a faulty sensor or an issue with the wiring.
P0113, P0118: These codes are related to the intake air temperature sensor and engine coolant temperature sensor, respectively. They suggest potential problems with these sensors or their circuits.
P0121, P0123: These codes pertain to the throttle position sensor, indicating issues with the sensor or its circuit.
P0338, P0343, P0348, P0368: These codes are associated with the crankshaft or camshaft position sensors. They may indicate problems with the sensors or the related circuits.
P0393: This code is specific to the camshaft position sensor circuit for camshaft 2 in bank 2.
P0553: This code indicates an issue with the power steering pressure sensor circuit.
P0778: This code is related to the 2-4 brake pressure control solenoid circuit. It could indicate a problem with the solenoid or its circuit.
P1343: This code is specific to the ignition coil group 4 and could indicate a problem with the coil or its circuit.
P2135: This code refers to a problem with the throttle/pedal position sensor/switch circuit.
P2716: This code indicates a problem with the pressure control solenoid "D" electrical circuit.
C1201: This code is related to the engine control system malfunction and could indicate a problem with the ECU or a communication issue between the ECU and other modules.
Please go over this guide as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over these guides and get back to us.
Jun 11, 2023 at 6:30 PM
