I have a 2007 R56 N14 mini copper, for a long time now the car has struggled to start on the first attempt once it has been sat for a long period of time. I have replaced the low-pressure fuel pump, HPFP, fuel filter, spark plugs, camshaft position sensor and changed the battery but none of these seem to have solved the issue. The car appears to run fine and starts on the second attempt but struggles on the first one. I have had the fuel pressure measured at 5 BAR but am now running out of ideas for what could be causing this issue. Any help you could give would be greatly appreciated. thank you
Feb 7, 2025 at 3:11 PM
