Fans will not start. The cylinder head temperature sensor replaced, new engine cooling fan resistor, engine cooling fan relay replaced. All fuses good, wires ring out, fans start when jumped. Fans will start when the ground wire from relay to PCM is grounded.
Aug 16, 2017 at 7:45 AM
