Engine cooling fan wiring diagram needed
1988 PLYMOUTH SUNDANCE
200,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
TED CRAWFORD
Engine cooling fan is not working. need a wiring diagram please.
Feb 28, 2017 at 2:46 PM
CARADIODOC
  • 34,306 POSTS
I am not able to post diagrams, but there is not much to this one. Find the radiator fan relay, then, while the ignition switch is on, feel that relay, then unplug the two-wire coolant temperature sensor. If the relay clicks, that entire half of the circuit is working.
If that is okay, use a test light, (not a digital voltmeter), to check the voltage on the gray wire in the relay's plug. If that is missing, the fusible link is burned open. Suspect the fan motor has tight bearings. You can verify that by spinning the fan by hand. Replace the motor, then the fusible link.
Feb 28, 2017 at 3:44 PM
WRENCHTECH
  • 20,761 POSTS
This diagram is for a car with AC. https://www.2carpros.com/images/external/42234331.gif
Feb 28, 2017 at 7:38 PM
CARADIODOC
  • 34,306 POSTS
Thanks brother Wrenchtech.
Mar 1, 2017 at 6:24 PM
WRENCHTECH
  • 20,761 POSTS
Any time Doc
Mar 1, 2017 at 6:25 PM
TED CRAWFORD
Thank you all for the information Got it fixed with the diagram sent
Mar 2, 2017 at 5:55 AM
CARADIODOC
  • 34,306 POSTS
What was the solution?
Mar 2, 2017 at 4:38 PM
