I replaced the original cooling fan (3 wire) with a 2 wire. In essence, I replaced the 2 speed fan with a single speed fan. Should I hook up the single speed fan to the wire that supplys low speed or to the wire that supplies high speed. I know which is which and the one that is ground. Or should the high and low speed wires be connected together and then connected to to the motor? Thank you in advance for any insight you may have!
email: [email protected]
Mar 22, 2017 at 7:26 PM
