Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Transit
Engine Cooling
Coolant Temperature Sensor
Where is the engine coolant temperature sensor located?
2018 FORD TRANSIT
110,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
YASUYOSHI CHICA CHIKAZAWA
MEMBER
1 POST
FOLLOW
overheat problem.
i needs know location of engine coolant temperature sensor.
Aug 13, 2021 at 7:37 PM
CERTIFIED EXPERT
This vehicle has a cylinder head temperature sensor (CHT). The sensor is located on the rear of the right cylinder head.
If you look at the attachments below, they provide the directions for removal and replacement.
I hope this helps. Let me know if you have other questions.
See pics below.
Aug 13, 2021 at 10:22 PM
