Engine coolant smells like a solvent
1998 FORD EXPLORER
217,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
OUT OF THE BOX
  • 7 POSTS
What can cause the engine coolant to smell like some kind of solvent? There was some yellow milky substance under radiator cap, but did not see much inside the radiator. It did not show under oil fill cap or inside valve cover or on engine dip stick.
I found coolant level to be 1.75 gallons low and possibly cooked.
Pep Boys told me that (if) it is not oil or transmission fluid that some radiator stop leak products can cause this also. PS: I found the oil level in engine to read 2.75" higher than the max fill level on the dip stick. I have not yet drained the oil to check for coolant filling up the oil pan.
I just bought this car without being able to open the radiator cap until hours later when it had cooled down. = Dumb purchase.
Sep 19, 2018 at 3:05 AM
Good morning.
Yes, it sounds like you have coolant in the oil from possible head gaskets or an intake manifold.
You will need to have a leak down test done to confirm the results.
It sounds like you need some major work.
Sep 19, 2018 at 6:20 AM
OUT OF THE BOX
  • 7 POSTS
Hi Roy and thank you for the advice. Since the most of the six spark plugs on this vehicle are very hard to get to, would a good place to start be the (chemical block test) for hydrocarbons in the coolant? Today I tried to check for coolant in the oil by bleeding some oil and/or coolant from the oil pan, but just could not get the oil drain plug loose. Maybe vise-grips and a mallet are needed? Since some antifreeze types fluoresce quite well under UV light, I tried using a ultra violet flashlight (like for checking for leaks in an AC system with a dye) on the dip stick, inside valve cover and in the radiator, but it did not reveal much, not even on the coolant in the radiator. Maybe other types of antifreeze would fluoresce better.
Sep 20, 2018 at 12:47 AM
The chemical test would be a good start but I do not always believe the results.
Yes, the plugs are a pain to remove to but to do the diagnostic correctly. It is the right thing to do.
As far as the oil drain plug, it sounds like you rounded it off. If that is the case then yes, you will need to not only get it loose, you need to remove it and replace it with a new one.
The UV kits come with a different lens. One is for Freon, one is for oil and one is for coolant. Did you try this?
Sep 20, 2018 at 1:11 AM
OUT OF THE BOX
  • 7 POSTS
Hi Roy, no, I have not yet tried the UV kit, I did not know about them. I did manage to get the oil drain plug out and allowed approximately (one) ounce of cold fluid to drain into a clear plastic bottle, see image. Then drained out (one quart). But did not see any more antifreeze, but the oil color is a dark brown/black color using a white light LED flashlight, viscosity seemed more like warm oil, not like a milkshake. Question, how can the hydraulic lifters can be flushed after the repairs are done? Also, what is your opinion about those head gasket sealant products like bars leaks ans steel seal for a temporary fix? I tried Bars leaks on my 1991 explorer's V6 a few years ago, it seemed to work for a while as long as it was not a cold night, but then the coolant leak came back. I am thinking of retiring both the 1991 and 1998 Explorer's to California's salvage yard in the sky, but with the 1998, I cannot do that this month. Horse and buggy days were easy, but not allowed now, too much methane.
Sep 21, 2018 at 6:40 AM
The coolant is no good in the oil. Most likely a head gasket. I would do both gaskets while the job is being done.
No to the head gasket additive. It has no effect on a head gasket. All it does is clog up the radiator and the heater core.
There is no flush for the lifters. Just use good clean oil.
Sep 21, 2018 at 7:32 AM
OUT OF THE BOX
  • 7 POSTS
Hi Roy:
To flush or not to flush. With antifreeze/water in oil and combustion gasses in coolant
after the leaks are repaired, would you recommend an engine flush? I have read many articles from on line mechanics that disagree with this issue. Some say, "no way, it will damage the engine" and others say "you have to in order to prevent the same acidic compounds from continuing to damage engine".
Same question for the cooling system, can you recommend any product that addresses removal of combustion gasses and or oil in coolant and the acidic conditions it creates?
Thanks for your help.
Sep 24, 2018 at 8:05 AM
Yes to flushing.
The engine, I would use Sea Foam. You can get it at a parts store. Follow the directions and it works very well.
Yes, to the cooling system. You need a machine to do the flush. Most shops have the machine. They add an additive to remove dirt and debris from the system.
Sep 24, 2018 at 10:30 AM
OUT OF THE BOX
  • 7 POSTS
Question, the additive to remove dirt and debris from the cooling system that most shops have, does it also (cleanse) the system of gasoline and combustion gasses? So that future chemical block test of the radiator will not give false readings for a previous problem.
Thank you much.
Sep 25, 2018 at 11:18 PM
Yes it does. The best method for this type of flushing is to use a flushing machine. That circulates fluid and cleaner throughout the system ensuring you get all of it out of the system.
Doing just a drain and fill will not get everything out of the system.
Sep 26, 2018 at 3:24 AM
