Engine coolant sensor location and replacement
2012 LINCOLN MKX
82,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GREY BRANTLEY
I need the engine coolant sensor location . Also need replacement instructions.
Oct 21, 2020 at 8:29 AM
BMDOUBLE
  • 1,139 POSTS
The intake must be removed to access the sensor, I've attached some illustrations that should help you out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Oct 21, 2020 at 8:54 AM
