It was running great until I flushed the system and then it started to overheat. I replaced the thermostat a couple times and it would drive good for a day or two and then overheat again. I finally got tired of it overheating and just removed the thermostat. It then never overheated. This was just a temporary fix until I could figure out why it was overheating. So today I finally got some time to start trying to figure out why it was overheating and when I took the radiator cap off the cap and inside of the overfill tank is loaded with brown/red gunk. I figure it is rust cause I was only running water until I figured out why it was overheating. After I get all the gunk out the system I plan to bypass the heater core and see if that is clogged up and causing the overheating. But I want to get all the gunk out first.
So, what is the best and most aggressive flush I can use to flush the system?
Oct 17, 2018 at 3:15 PM
