engine compatibility
2002 FORD MUSTANG
115,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MATTCORE11
My engine blew up. would a 4.6l 2 valve pi engine from a 2007 Ford Crown Victoria work?
Mar 24, 2019 at 12:57 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes it would. The SN95 Mustang from 1996 to 2004 where all 2 valve SOHC 4.6L. The P.I. cylinder heads came out from 1999 to 2004. This should be a direct fit. The hose coming from the heater core to the bank 1 cylinder head might need a little fabrication work to make it fit, but other than that, it should be a plug and play engine swap. The 2005 models is the start of the 3 valve SOHC cylinder heads. Let us know if we can help with anything else.
Thanks,
Alex
2CarPros
Mar 24, 2019 at 1:07 PM
