Engine codes
1992 DODGE DAKOTA
95,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
WAYSALJOH
What is the difference between obd1 codes and import codes? My engine code is 3 5 5.
Aug 27, 2018 at 7:55 AM
Good afternoon.
Did you do this with the key off and on three times and count the blinks?
If you did, 55 is end of the sequence and three would be the code.
Let me check.
Aug 27, 2018 at 11:49 AM
WAYSALJOH
Yes. What is code 3?
Aug 27, 2018 at 12:32 PM
It is usually a two digit code, like one is missing.
Do it again. key on and off three times. Then count the blinks. 55 is end of codes and not a code.
Aug 27, 2018 at 12:44 PM
