If the check engine light is flashing, it is likely related to an ignition misfire. How is the vehicle running or is it running?
Here is what I need you to do. We need to check for diagnostic trouble codes that may point us in the right direction. This vehicle has an OBD1 system which doesn't require a scan tool for reading codes. All you need is a short jumper wire.
Follow the directions in the link below and let me know what you find.
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Let me know,
Apr 18, 2023 at 7:36 PM
