DTC 0455 is that a leak has been detected in your vehicles Evaporative Emissions System(EVAP). Your EVAP system consists of a charcoal canister, vapor line going from your fuel tank to the canister, and lines to a solenoid or a EVAP Purge Flow sensor, and more hoses/lines going into the throttle body. Basically this is emission control system where fuel vapors are routed and stored in a charcoal canister until the vehicles Power-train Control Module(PCM)/Electronic Control Unit(ECU) a.k.a. computer decides it is a good time to introduce it into the throttle body to go into the combustion chambers and disposed of in the normal combustion cycle of the engine. Here is a link to a guide that should help you run down the problem:
https://www.2carpros.com/articles/evap-system-code-repair
Go through it and let us know what you find out. If you need further assistance, we can go from there.
Thanks,
Alex
2CarPros
Feb 7, 2019 at 9:26 PM
