I have check engine light on. The code is P0304 which is a misfire on cylinder four. These cars have three coil packs that run two spark plugs on each coil. My question is, if it was a bad coil causing this problem, would it not be making two cylinders misfire instead of just one? Because each coil runs two spark plugs. Unless a coil can go bad and only mess up one cylinder?
Mar 12, 2018 at 10:29 AM
