My 2004 C230 won't start. I have a check engine light and two engine codes P0128 and P0600. I got an oil changed last week by a mobile mechanic. He told me I need to replace my valve gasket cover and was going to charge me $130. He said there was a leak and the valve gasket cover needed to be replaced. Two days later my car wouldn't start...... and I had to get it towed home.
After reading several forums I thought it could be the crankshaft position sensor that needed to be replaced. After putting the key in the ignition and it sounds like it's cranking ... just not starting.
And then after researching the codes I received... maybe it's not that.
Any ideas.. please help. I can't afford to spend tons of money!
Sep 6, 2015 at 11:24 AM
