My car has code P0357?
2004 MERCURY GRAND MARQUIS
246,509 MILES • 4.6L • V8 • 2WD • AUTOMATIC
PETPARENT
  • 15 POSTS
My car has code P0357. I repaired it before by putting a new spark plug and a new spark plug insert into the cylinder head. It continues to give me the code even after removing the old plug and replacing it. I also removed a piece of rubber from the spark plug chamber. I thought that would solve my problem. Service Manuel said it was a circuit malfunction to check the circuit.
Dec 23, 2024 at 7:48 AM
It is common for the ignition coils to go out on these engines, I would replace the coil with a new unit.
A P0357 code indicates an issue with the Ignition Coil "G" Primary/Secondary Circuit.
This video will show you how:
https://www.youtube.com/watch?v=e68QXyBAiZo
Happy holidays!
Dec 23, 2024 at 1:37 PM
PETPARENT
  • 15 POSTS
Should I check the circuit from the wiring harness for the engine and possibly look for short circuits or other problems in the ignition coil connector?
Dec 25, 2024 at 12:41 PM
Yes, you can inspect the wiring and connector but most of the time it will be the ignition coil.
Dec 26, 2024 at 11:30 AM
PETPARENT
  • 15 POSTS
Yes I will inspect the wiring and check it out with my test light and multimeter.coil was last change and check almost 2 years ago.
Dec 30, 2024 at 8:29 AM
Okay, also make sure the spark plug is not cracked, this may cause the issue as well.
Dec 30, 2024 at 9:32 AM
