Bought petrol and since then the car engine check light came on. when I start the car in the mornings it gives a sound like its losing power/buck.
Dec 13, 2017 at 8:51 AM
MHPAUTOS
CERTIFIED EXPERT
First make sure that the petrol filler cap is on tight (if its a non cap type of filler that is okay). get a scan done and report back what the code is so we can check it out and advise what has caused it to come on, start here.
Dec 14, 2017 at 4:16 AM
OSHANE
MEMBER
Okay, will do ASAP.
Dec 14, 2017 at 4:40 AM
OSHANE
MEMBER
Did the scan and its showing that the transmission range sensor is the prob,but prior to that when the machine was install at first the check light came off but came back after a few test drive what do u think?
Dec 15, 2017 at 8:44 AM
MHPAUTOS
CERTIFIED EXPERT
i would not expect that the range switch would be the cause, i would clear the code and do a general tune and see if that improved things, a faulty range switch would normally stop the engine starting, i would also get an on demand transmission scan done, this will look deeper into the transmission electrical system, just in case there is a deeper problem there.
Dec 16, 2017 at 2:17 PM
OSHANE
MEMBER
Ok
Dec 16, 2017 at 5:54 PM
OSHANE
MEMBER
Sometimes when I try to put the car in drive mode or just moving the shift any at all its tough and the sport mode button doesn't work??
Dec 18, 2017 at 11:39 AM
CERTIFIED EXPERT
Yes it sounds like the transmission range sensor is out and needs to be replaced. Here is a guide to help you test to confirm the failure.
