For the last three weeks after initial warm up upon acceleration the engine bucks. About fifteen minutes goes away. No stalling had plugs replaced was told wires are good had cap and rotor replaced four months ago and fuel filter replaced. Check engine lite comes on mechanics check code. 02 sensor and misfire. Fuel,pressure was also checked. Only happens after initial startup. The vehicle is in excellent condition. The soaked all high tension components also. Including compression test shows normal. Can you help?
Sep 27, 2017 at 2:24 PM
