Hi, I have the car listed above with a VQ35DE and 5 speed manual. I bought the car as it is and nothing I have done has helped or changed anything and I'm pretty much out of ideas. When pressing the gas, the engine just bogs down. If I barely press the gas pedal it will rev slowly but will eventually rev up to over 4,000 RPMs. It was throwing codes for both the VVT solenoids, and they tested bad so replaced them with Hitachi solenoids. Cleaned both cam sensors. Changed oil and filter. Air intake tubing was cracked so replaced with a CAI. Tested MAF with a multimeter and tested good. New spark plugs and valve covers. Pulled intake plenum and cleaned it and the throttle body with new gaskets. Currently has open manifolds as I took the exhaust off to check if cats were clogged. I checked oil pressure with a gauge and at hot idle it shows 15 lbs. I'm sure there's more I'm forgetting. It still shows codes for both VVT solenoids and last time I started it also showed a code for the knock sensor. Haven't had a chance to test the knock sensor yet. Nothing I have done has changed the way the car runs at all. I'm really wondering if throttle body could be bad but cannot find any way to test it. Any help is greatly appreciated.
Jan 6, 2024 at 6:32 PM
