In what places can I find the engine serial number?
What does decoded number mean?
Oct 3, 2018 at 7:26 AM
CERTIFIED EXPERT
It is usually stamped on the front of the block where the cylinder heads are bolted on. What problem are you having? Not sure what you mean by decoded number?
Oct 4, 2018 at 11:47 AM
2018GRANDCARAVAN
MEMBER
Front of block on a Pentastar V6 ?
Need to determine date of manufacture.
Oct 4, 2018 at 2:13 PM
CERTIFIED EXPERT
I called the dealer they said is was on left side of engine down by the starter on a stamp or there is a barcode and a number under the code which will be on the valve cover which will be the serial number.
Oct 6, 2018 at 11:36 AM
2018GRANDCARAVAN
MEMBER
What does each letter or number mean?
Oct 7, 2018 at 11:00 AM
CERTIFIED EXPERT
You would need to call the dealer for that.
Oct 8, 2018 at 9:46 AM
2018GRANDCARAVAN
MEMBER
Thank you.
Oct 8, 2018 at 10:25 AM
CERTIFIED EXPERT
Use 2CarPros anytime, we are here to help. Please tell a friend.
