engine back fires when at normal temperature
2006 DAIHATSU
24,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
PHIL.123
engine : 1.3 K3-VE
Extol van
engine starts okay runs okay, cold until it reaches normal running temperature then when you accelerate it back fires and has no power.
replaced the engine coolant temperature as it had a fault stored for it. no faults get entered in the engine control unit while the fault happens. checked the valve clearances all okay and replaced the spark plugs. catalytic converter will glow red. any ideas?
Jul 1, 2017 at 2:24 AM
It sounds like the spark plug are cross firing, have you replaced the spark plugs recently? If not here is a guide to help you get the job done.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
https://www.2carpros.com/articles/engine-backfires-while-running
Jul 3, 2017 at 12:56 PM
PHIL.123
all spark plugs are new
Jul 4, 2017 at 12:46 AM
It sounds like the catalytic converter might be plugged, here is a guide to ehlp you confirm.
Please run this test and get back to us we are interested to see what it is.
Jul 4, 2017 at 11:29 AM
