Engine and transmission swaps
2003 FORD F-150
164,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BRIAN STRAIGHT
I own three F-150's with the same 5.4 v8 (believe).
I have an 2003 F-150 XLT Lariat 5.4 v8.
I also have (two) 2004 F-150's with 5.4 v8 engines.
One is an XLT with a bad transmission the other is the XLT Lariat with a bad engine.
I want to put the engine from the 2003 lariat into the 2004 F-150 XLT Lariat . Can this be done?
Also, I want to put the transmission from the 2003 XLT Lariat into my 2004 XLT, can this be done?
This way I could have two operational trucks.
Apr 26, 2018 at 1:20 PM
STEVE W.
  • 15,113 POSTS
Ford made a lot of changes between 2003 and 2004. You would need to verify which engine and transmission each truck actually has. For instance the 5.4 in the 2003 should be a late two valve engine while the 2004 could have either a two valve or the "new" Triton three valve. Those use different control systems so are not a bolt in swap. Same is true for the transmissions. The 2003 should have a 4R70W in it while the 2004 is probably the newer 4R75W, again the electronics are different enough that they are not a direct swap.
You should be able to easily swap the good 2004 engine into the 2004 Lariat. However, I would do any possible maintenance on it before you bolt it in.
Apr 26, 2018 at 10:11 PM
