Engine and fuel pump problem
2007 SATURN ION
16,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
SHATORIA25
Engine: My number two cylinder is not getting any fire. I took my car to a mechanic, he test it out by using a pressure valve (it looks like a blood pressure culf). It was only getting 30 compressor an not more like it suppose to. It do misfire when you drive the car. I want to get the engine rebuild but I don’t know if it would be better to get a new engine or get it rebuild?
Fuel pump: Where you put the gas nozzle at to pump your gas in the car is broke. I have to fix it before I can put the nozzle in to pump the gas. Plus I can smell gas even though I don’t see any gas leak or anything. My gas do runs out quick too. Do I need a new fuel pump or what?
Nov 5, 2019 at 6:07 PM
Hi:
As far as the engine issue, it really matters what needs done to restore compression to that cylinder. If it is only compression, there may be a stuck valve or a head gasket issue. Did the mechanic diagnose why the pressure is low? Also, if you could upload a picture of what you are referring to as far as damage to the fuel filler area, it may help me.
Nov 5, 2019 at 8:03 PM
The fuel filler question needs to be separate from the low compression issue. It sound like you could have a broken valve spring. Here are the reasons for low compression:
https://www.2carpros.com/articles/the-reasons-for-low-compression
Please post your new question here, you must be logged in.
Nov 8, 2019 at 12:29 PM
