My engine runs smoothly at 2000rpm and over but under that it shudders like it has a misfire. Have checked spark plugs, new leads and clean plugs. Checked fuel filter and pump and replaced fuel. Fitted a new Mass air flow sensor (though this itself could still potentially be an issue as I cannot source OEM).
It is almost stalling when you start to pull away almost like it is flooding or not getting fuel, not sure which. It will not accelerate smoothly until RPMs exceed 2,000 at which point it runs smoothly again.
Engine light is coming on, so I suspect a sensor somewhere.
Oct 20, 2023 at 1:03 PM
