Erratic engine RPMs
2005 NISSAN X-TRAIL
238,489 MILES • 2.1L • 4 CYL • 4WD • AUTOMATIC
MANYPEOPLE11
I started my vehicle and my RPMs skyrocketed and then bounced up and down. I put it in reverse and it slammed full speed in reverse and my brakes are barely working. I put it back into park and the RPMs stayed max.
Jun 5, 2021 at 11:06 PM
This could be a couple things, but what I would suggest we start with removing the intake tube to the throttle body and restart the engine and make sure the throttle is not sticking.
https://www.2carpros.com/articles/how-a-throttle-body-works
Basically you will see the throttle plate is remaining open and not moving. So if it is stuck open then that is the issue.
I attached the info below on the throttle body but I suspect the cable is the issues and we need to start with making sure it is not stuck open.
Let us know if you have questions on this. Thanks
Jun 6, 2021 at 4:54 PM
