Engine will not idle
1996 SATURN SL2
238,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
MICHELLE LENOIR
Engine will start but will not idle. It runs good at high rpm's.
Oct 24, 2017 at 7:00 PM
Check the following; make sure there are no engine vacuum leaks. Also, check the idle air control (IAC) for proper operation and make sure there it is clean. Make sure the throttle body is clean and not slugged. Finally, with that many miles, keep in mind engine compression could be an issue. If there is more than a ten percent variation between cylinders, you could get a rough idle. However, since it will not idle, chances are it is one of the items I mentioned.
Oct 25, 2017 at 6:51 PM
MICHELLE LENOIR
So it was the the throttle position sensor. It's finally running now but smokes really bad.
Nov 4, 2017 at 4:13 PM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one what color is the smoke out the tail pipe?Also has the coolant temp sensor been changed?They go bad and can cause smoke issues starting and idle issues.
Nov 5, 2017 at 10:14 PM
MICHELLE LENOIR
Black smoke and yes the temperature control sensor has been changed.
Nov 6, 2017 at 1:29 AM
SATURNTECH9
  • 30,869 POSTS
So you also replaced the throttle position sensor?Also have you scanned the computer for codes?
Nov 6, 2017 at 1:39 AM
