On the way to work. Heard a grinding, hard knocking sound coming from engine. Started seeing smoke coming from the hood. It was white smoke. So I pulled over and saw that there was oil leaking all under the bottom of the engine block looks like coming from the oil pan. I cannot see a hole or anything. Tried turning the car over once again and it started then but is grinding and would shake bad. Now it won’t start and all of the oil has leaked out.
Nov 11, 2024 at 11:57 PM
