Engine Shakes while driving slowly?
2018 MERCEDES BENZ GLA250
58 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
HACH NGUYEN
The engine shakes when I am driving forward slowly or turn left, right slowly. I don't know why.
Sep 7, 2024 at 10:50 AM
Do you have a check engine light on? If so, we should get the codes that are stored, here is a guide to help:
Are you sure it is the engine because my wife has this car, and the rear differential fluid was broken down and makes the car shutter. Check out this video:
https://youtu.be/kZ4KYSPx8xo?si=EYh58uAegnqHt91G
Please upload videos in your response of any problems so we can see what to help you with.
Sep 7, 2024 at 6:35 PM
Yep, the fluid in the rear differential breaks down and does not allow the differential clutch discs to disengage which makes the "bumping" sensation. The differential only holds less than a quart of their special fluid. Each quart is $75.00 at the dealer, and you must use their fluid. How many miles are on it?
Sep 8, 2024 at 11:07 AM
We have seen the dealer replace the rear differential for $5,000.00 to fix this problem, so the fluid is a cheap fix. Please let me know what you find.
Sep 9, 2024 at 8:05 AM
