In the middle of replacing lifters due to a tapping sound in the driver rear of the engine i came across a piston with the exact design of one of the valves stamped in the top of it. It doesn't appear to be damaged and as far as i know it is seating fine truck ran great. What would cause this? The lifters and cam lobes are still like new. The rocker assembly is getting replaced but it wasn't that bad. Could the valve spring tension be weak causing it to not lift the valve at the proper time/speed?
May 8, 2023 at 2:59 AM
