Knocking noise in engine
1999 SATURN SL2
216,307 MILES • 4 CYL • MANUAL
LA.VERO
  • 40 POSTS
Car has a knocking sound and gets louder when I step on gas. What could it be and what is the cost to repair it? Is it worth fixing? Please help.
It was low on oil when knocking started. But I added four quarts. Now it is not as loud but still knocks.
May 2, 2018 at 9:29 PM
SATURNTECH9
  • 30,869 POSTS
If you had to add four quarts of oil to the engine then there was no oil in the engine.It sounds like you most likely spun a rod bearing.your best bet for repair would be a used engine.let me get you a guide to help you along.
May 4, 2018 at 8:11 AM
SATURNTECH9
  • 30,869 POSTS
SATURNTECH9
  • 30,869 POSTS
Let me know what you find. I would say a rod knock.
May 4, 2018 at 8:15 AM
LA.VERO
  • 40 POSTS
Thank you and around how much would engine swap cost?
May 4, 2018 at 3:31 PM
Can you check to see if you have a loose spark plug? That is what it sounds like to me.
https://www.2carpros.com/articles/how-to-change-spark-plugs
May 6, 2018 at 4:53 PM
SATURNTECH9
  • 30,869 POSTS
I did not see a video there before. Yes it does sound like you could have a loose spark plug.
May 6, 2018 at 6:53 PM
