And you're not seeing any fuel leaking anywhere? Not around the base of the fuel injectors, to smell raw fuel like that sounds more like an exterior leak, a really rich running engine will cause smoke out of the exhaust pipe, and the spark plugs will have excessive carbon build up on them, and the idle starting to hunt if that's what you mean by loop, is something that happens when the ECM has trouble maintaining the desired rpm, a vacuum leak can cause that,
If you think it's a fuel delivery issue, checking the fuel pressure while running and then when the key is turned off for possible pressure leaking down fast would be one of the first tests I would do. If the pressure leaks down fast after the key is off, it can be the injectors leaking down, or the check valve in the fuel pump leaking down,
I just had a vehicle this week with a fuel pump leaking down after the key was off, and it turned out to be the pump assembly leaking down, and after a while of driving the fuel pump would only reach half the pressure spec it should have causing a no start condition.
On other thing you can check is the Canister Purge valve, if its stuck open due to a charcoal canister failure, the purge valve can actually draw fuel threw the Evap vapor system into the intake manifold, Ill try to find a picture of the purge valve for you,. It should be on the driver side of the engine compartment, a 2-wire purge solenoid. With a red wire and a grey with yellow stripe wire.
Jan 31, 2025 at 1:58 PM
