turns over but wont start no spark/no fuel
1994 GMC SIERRA
200,000 MILES • 5.7L • V8 • RWD
KEISHA WALKER
Car turns over but wont start. no spark/no fuel. The plug that plugs into the pickup coil does not have power, but the other plug has power.
Sep 10, 2016 at 3:33 PM
HMAC300
  • 48,601 POSTS
if it has a tachometer try disconnecting that wire if it will by it self. then check pickup coil 400-1000 ohms. take ignition module to auto parts to test if it is good or not. if you have no spark fuel will be shut off as well.
Sep 10, 2016 at 4:39 PM
