Engine running rich
2013 NISSAN ALTIMA
113,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MICAHJJOYNER
Running too rich.
Jan 23, 2020 at 5:56 AM
What makes you say it is running too rich? Do you smell fuel or have you monitored the o2 sensors?
The answer to this will lead us in different paths. If you smell fuel then I suspect you have a purge valve issue. If you have monitored o2 sensors then you either have an injector issue or another intake sensor like the Mass air flow sensor, issue that is causing the PCM to dump too much fuel.
Let me know and we can go from there. Thanks
https://www.2carpros.com/articles/mass-air-flow-service
Jan 23, 2020 at 5:06 PM
