4 out of the 6 spark plugs are oily
2000 FORD MUSTANG
2,000,000,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRIS KINARD
  • 94 POSTS
yes, i took the spark plugs out of my car and 4 out of the 6 where oily. i have a lot of miles and not a lot of cash and want to keep my car. What would you recommend for me to keep my vehicle going? I am using a synthetic oil royal purple 5- 30 i think, and have motor craft spark plugs.
Aug 14, 2020 at 11:28 AM
CHRIS KINARD
  • 94 POSTS
I forgot my oil pressure is a little over half.
Aug 14, 2020 at 11:32 AM
In all honesty, if rings are worn there isn't a lot that can be done other than an overhaul. How much oil is it burning? Have you checked engine compression to see if it is exceptionally low?
Let me know. Also, let me know how much oil it's burning, does it only happen at specific times?
Aug 14, 2020 at 12:08 PM
CHRIS KINARD
  • 94 POSTS
i haven't checked the engine compression, and i put maybe a 1/4 cup every three days oil in.
Aug 14, 2020 at 9:09 PM
Take a look through this link. It explains the most common causes of burning oil. Let me know if it helps. If it doesn't, we need to do more testing.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Aug 14, 2020 at 9:55 PM
CHRIS KINARD
  • 94 POSTS
Hey, i have no smoke coming through my exhaust out tail pipe and yes i know i'm supposed to have catalytic converters but i hollowed them out.
Aug 15, 2020 at 10:04 AM
CHRIS KINARD
  • 94 POSTS
and i change my oil probably every month i'm OCD on it, LOL.
Aug 15, 2020 at 10:07 AM
LOL. I do mine every 2,000 miles. Everyone thinks I'm crazy. Honestly, if you have no blue smoke, are you sure there are no leaks? If it still had converters, I've seen them hide blue smoke. But that is only when they use a really small amount. Otherwise, it shows up.
Interestingly, most manufacturer's consider a quart of oil used in 1,500 miles normal. Do you fall into that range?
Aug 15, 2020 at 11:41 PM
CHRIS KINARD
  • 94 POSTS
Yes, I have been having oil coming our behind the crankshaft and i just noticed a leak where the drain plug is and a little leak right behind the drain plug where that plastic circle piece is on the pan.
Aug 16, 2020 at 12:37 AM
Chances are those are the cause. Is it possible for you to take a few pics of the leaks and upload them for me to see? That way I may be able to make some suggestions.
Aug 16, 2020 at 8:54 PM
