I would replace that plug not uncommon for a plug to be bad out of the box. Drop them once and the porcelain can crack enough to cause a problem.
Shaky usually means misfires. If you can get the codes read it might point you to the same cylinder or to the one you put the plug in. In the states most of the parts stores will read the codes for free not sure if they do that where you are.
However as you seem to be interested in doing your own work you might consider getting your own DIY type scan tool. There are a few that are $100-150.00 that do more than just read the codes.
This one has pretty good reviews and I know a few folks who have used it and say good things.
https://www.amazon.com/Topdon-Universal-Diagnostic-Professional-Elite/dp/B01MCXXVH1
You can download the manual for it and see if you think it would help you. Plus if you get used to using it you might have friends who you can help if they have problems.
Oct 11, 2017 at 9:00 AM
