These questions are always hard to answer unless the engine was an option for the vehicle in the same or similar model years. The technical answer is yes, most any engine can be made to fit into any vehicle. The question is how hard and how much work it will require to get it to operate.
The fact that this engine doesn't appear to be an option for the Corolla in any model year that I can find so I assume it is coming out of a different vehicle?
If that is the case, then you will not only need to modify the mounting location but you will need a transmission that will work or at least an adapter bell housing (If they exist) so that the engine and transmission can be married.
This is all just to get the engine physically in the vehicle. Then we are going to have a whole bunch of hurdles to get it to run including wiring, modules, and needed sensors. Then once it is running we have to think about axles and suspension as that will most likely need to be altered to be able to get the vehicle to even move.
Long story short, unless you have the patience and ability to accomplish this I would suggest looking for a kit that you can swap an engine into the vehicle. This is the route that I would personally go because even though I could figure all this out, it would be cheaper and easier to look for a kit. They make all sorts of different kits that come with everything you would need to fit the engine and get it to run. Just do some internet searches and you will find all sorts of options.
Let us know if you have other questions.
Dec 19, 2020 at 11:10 AM
