My truck has a very rough idle when i turn on the A/C, as well it really has bad idle to the point the truck will stall. if i drive it's fine the moment I'm at a light i have to watch it otherwise it will stall. so i have to shut the A/C off before it does truck also has a p0302 code. I've replaced the coil pack for it and all of them twice nothing's changed. I've changed the spark plugs, nothing's changed. I've also changed the MAP sensor twice, and cleaned the throttle body, i have no idea what's wrong. The reduced engine power light came on when p0106 and p0107 came on. The p0302 code comes on when i fill up my tank with has then goes off when its 1/2 way full sometimes and there is a bad rattling noise on bottom of the truck. The transmission goes into gear perfectly, nothing wrong; no missing gears, nothing. goes into gear fine, no hesitation. I have no idea where this rattle noise could be either. If you have any ideas on any of these please let me know. thank you
Apr 21, 2022 at 8:44 PM
