Engine only runs in reverse
1988 CADILLAC SEVILLE
121,000 MILES • 4.5L • V8 • 2WD • AUTOMATIC
ACTIONAUTOREPAIR
  • 19 POSTS
Engine will not run in idle/drive/park but runs fine in reverse.
Sep 14, 2020 at 3:29 PM
Good evening,
Do you mean it will idle in reverse and move fine but shuts off as soon as you put it in drive?
https://www.2carpros.com/articles/stall-at-idle
Does it idle in park?
They had an idle speed control motor on the throttle body but if it was bad, it would do it all the time.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Can you check for codes by pushing the off and warmer buttons at the same time and give me all the E codes?
Sep 14, 2020 at 3:48 PM
ACTIONAUTOREPAIR
  • 19 POSTS
Okay, will try that. never heard of that before.
Sep 14, 2020 at 5:25 PM
Keep me updated.
Sep 14, 2020 at 6:08 PM
ACTIONAUTOREPAIR
  • 19 POSTS
Got code E52 out of that car.
Sep 15, 2020 at 10:43 AM
ACTIONAUTOREPAIR
  • 19 POSTS
It runs badly in Idle/drive/park but as soon as you put it into reverse it runs fine. We did find some vacuum hoses that were broken fixed them.
Sep 15, 2020 at 10:46 AM
ACTIONAUTOREPAIR
  • 19 POSTS
Is E52 related to oil temperature sensor?
Sep 15, 2020 at 1:41 PM
The 52 is for the anti lock brake system. I attached the chart for you.
It has nothing to do with your issue.
Watch the idle control motor. When you put it in forward, does the arm come out and increase the idle?
Sep 15, 2020 at 2:16 PM
ACTIONAUTOREPAIR
  • 19 POSTS
Okay, will have a helper start the car and I will watch.
It's just so weird that it lopes and runs inconsistent in Drive/Park/Idle then in Reverse it runs perfect.
This one has me totally stumped.
I looked up on GM website the ECodes. What I found was low engine temperature was E52, would that affect the engine?
Could a temp sensor be out?
I will check the throttle body and the idle control asap and get back to you.
Thanks for your help. this is making me go crazy!
Sep 15, 2020 at 3:47 PM
ACTIONAUTOREPAIR
  • 19 POSTS
P.S. did not see your chart that you attached.
Sep 15, 2020 at 3:48 PM
ACTIONAUTOREPAIR
  • 19 POSTS
Alright we started it and the arm came out.
Sep 15, 2020 at 3:55 PM
ACTIONAUTOREPAIR
  • 19 POSTS
It's weird because like today it ran fine in drive but when we started driving it it lopes and runs inconsistent.
Sep 15, 2020 at 3:57 PM
Did the arm come out in drive?
No to the coolant sensor. It would effect both forward and reverse.
Sorry, I reattached the chart.
Sep 15, 2020 at 4:10 PM
ACTIONAUTOREPAIR
  • 19 POSTS
Yes the arm came out!
Sep 16, 2020 at 10:52 AM
Okay, that concerns me. This means it is working correctly and it should run and not stall.
The one thing that could cause it to stall is the torque converter. It could be locked internally and not releasing.
Sep 16, 2020 at 10:58 AM
ACTIONAUTOREPAIR
  • 19 POSTS
Thanks. will check that next.
Sep 16, 2020 at 8:15 PM
ACTIONAUTOREPAIR
  • 19 POSTS
You know that's funny, I mentioned that to my guys and got nothing but "no's couldn't be!"
Sep 16, 2020 at 8:20 PM
ACTIONAUTOREPAIR
  • 19 POSTS
I remembered from years ago having a car do that, but none believed me this last two weeks. ...
Thanks again for your quick responses will keep you posted..
Sep 16, 2020 at 8:21 PM
You are welcome.
Always glad to help.
Sep 17, 2020 at 4:08 AM
