Loss of engine power
2008 SATURN OUTLOOK
176,284 MILES • 3.6L • AUTOMATIC
VAUGHNDWAIN
Reduced engine power, car moves slow.
Nov 3, 2020 at 1:13 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
With the car being in reduced power mode there must be an engine fault. Is the check engine light on? The first thing is to have any stored engine codes scanned. If you don't have access to a scanner or code reader most auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved:
https://www.2carpros.com/articles/reduced-power-limp-mode
Once you have the code or codes read get back to us with the code information and we can then properly diagnose. Hope this helps and thanks for using 2CarPros.
Nov 3, 2020 at 2:00 PM
There are a number of things we need to start with. Here is a guide that explains the basics:
https://www.2carpros.com/articles/engine-has-low-power-output
Let's start going through this and checking these things so we can see what turns up.
Also, we need to check for codes.
Let us know what you find with this information and we can go from there. Thanks
Nov 3, 2020 at 2:02 PM
