hi, a couple months ago i did change spark plugs, wires, coils,oil, oil filter, air filter manifold gasket but for some reason after that the car ist no running well it has the engine sakes the rpm needle is not on the 1000rpm and it has gas smell come out the exhaust, if i put it in gear and hit the gas pedal its ok but if just put it in gear without hit the gas shuts off. i did already check the wires and they are alright everything its on the right position please help with this problem
Apr 21, 2016 at 5:58 PM
