eng misfiring while driving and very bad at idle
2003 MAZDA MPV
138,000 MILES
JOSHUARMILLER
  • 4 POSTS
van idles very bad fixed numerous vaccum leaks cleaned mass air flow sensor fuel pressure at 70 psi. there are no codes except for a post cat code on bank 2 for heater circuit. can't get scanner to give me mode six data. tried unplugging coils to look for a "no change condition". looking for a place to start testing but don't know where to start any ideas
Aug 25, 2013 at 1:12 PM
KHLOW2008
  • 41,814 POSTS
Were the spark plugs checked?
Aug 26, 2013 at 11:07 AM
JOSHUARMILLER
  • 4 POSTS
They were replaced with the fuel injectors
Aug 26, 2013 at 11:29 AM
JOSHUARMILLER
  • 4 POSTS
Plugs are soaked in fuel
Aug 26, 2013 at 11:31 AM
KHLOW2008
  • 41,814 POSTS
Plugs are soaled in fuel indicates excessive fuel is getting to the cylinders and it could be a fault with the pressure regulator or engine coolant temperature sensor.
Use the casn tool to monitor the ECT to see if it is working correctly.
Aug 26, 2013 at 11:37 AM
JOSHUARMILLER
  • 4 POSTS
Will do thanks
Aug 26, 2013 at 11:39 AM
KHLOW2008
  • 41,814 POSTS
Any update on this?
Sep 14, 2013 at 9:35 PM
