They will tell you the same thing. The switch itself simply snaps into the trim panel. There is nothing else that holds it in place. No other reinforcement behind it to attach to because then you couldn't remove the trim panel itself to replace the switch or the dimmer control.
If someone pushed the switch hard it broke the switch, either the two small sections that keep the switch from being pushed through the panel or the internal switch assembly itself. They are not made for any abuse or even constant use.
Here is the GM factory diagram and switch replacement instructions pulled directly from GM tech system.
Removal:
1 Disable the SIR system
2 Remove the instrument panel (I/P) cluster trim plate from the I/P carrier.
3 Disconnect the dimmer switch electrical connector if required.
4 Disconnect the electrical connector from the hazard warning switch.
5 With a small flat-bladed tool release the retaining tabs for the hazard warning switch.
6 From the back side of the I/P cluster trim plate, push outward on the hazard warning switch. This will remove the switch from the I/P cluster trim plate.
Installation:
1 Align the hazard warning switch to the opening in the I/P cluster trim plate.
2 Push inward on the hazard warning switch until fully seated into I/P cluster trim plate.
3 Connect the electrical connector to the hazard warning switch.
4 Connect the dimmer switch electrical connector if required.
5 Install the I/P cluster trim plate to the I/P carrier.
6 Enable the SIR.
You can do as you wish but you will be wasting money.
Sep 25, 2017 at 10:33 AM
