Emergency brake will not release?
2007 JAGUAR S-TYPE
35,000 MILES • V8 • 2WD • AUTOMATIC
ED BRUSSMAN
The automatic emergency brake is in the locked position and will not release. Tried removing the static charge and it worked for a while then locked up again. The emergency brake release is free to move. Anchors and cables are free, fuse checked. Brake actuator I do not know how to troubleshoot.
Dec 19, 2017 at 9:08 AM
It sounds like the internal valve has a leak inside the APB system. Here are some guides to help you replace the unit and get the car fixed.
Dec 20, 2017 at 2:23 PM
ED BRUSSMAN
I will try this fix as soon as possible.
Thanks
Ed
Dec 20, 2017 at 2:35 PM
LANGSTON56
Parking brakes stick after sitting for a week or more. The only way to release brakes is keep shifting from park to drive until parking brakes release itself. This has been happening for about six months. I am just now beginning to become concern because I feel the time is near when I am out some where and the brakes will not release.
Mar 1, 2021 at 1:48 PM (Merged)
Have you checked all cables to make sure they are not rusted and sticking?
LANGSTON56
I checked the cables,all were OK. Once I allow the car to run for a while and switch from park to reverse the brakes normally release.
I have another question. Are you in an area that it is cold? Just wondering if heat from the engine is warming something.
JENSTA
Can´t release handbrake!
-13 C and Handbrake (HB) could not be released last night, put a blancet over each wheel and a heater on each and thuoght it would varm up and relaese,but not after a night! The wheel is varm. how can I release manually?
Does not help with taking away fuse-tryed. Hope to go on business trip 6h drive ,in 4hours.
Thankful for any ideas, Jens Sweden
JENSTA
Will now share how I fixed it myself.
I took off the cables to battery for 15 min and put back again and that way "restarted" the electronic system (had to find code for radio)and then I could release handbrake. I then took away fuse to handbrake so it will not get stuck again this winter. I have a manuel gearbox so I´ll just park in gear.
WRENCHTECH
  • 20,761 POSTS
Thanks for posting the fix. That's helpful.
